How do I hide containers to be imported into casaOS ?
Hello and sorry because I used Google translate (I speak French).
I absolutely need macvlan/ipvlan in order to assign static IPs to my docker containers. But casaOS doesn’t support this.
So as a solution, I create my container via the linux terminal (docker-cli), then in casaOS I just create an external link that points to the container’s ip. So I don’t have the container update, shutdown and restart function but this is not too serious for my use.
The problem is that on the casaOS home page, at the very bottom, I have my containers that I created which are visible to me as an application to import into casaOS. And that’s what I want to remove. How can I no longer have these applications having to be imported into casaOS?
THANKS
Legacy apps are unmanaged applications that run outside of CasaOS’s management system. Currently, there isn’t an option to hide them from the interface.
If you want a home screen that is customizable, you can install Homarr:
