How to change BG alarm values in Big-Bear Nightscout Docker container?
Hi,
I’m running the Big-Bear Nightscout container via Docker, and I want to adjust the alarm thresholds for:
  • BG Low
  • BG High
  • Urgent Low
  • Urgent High
Normally, I would do this by editing the config file, but with the containerized setup, I’m unsure where or how to set these values correctly.
Could someone please explain the right way to configure these thresholds in a Docker setup?
Also, should the values be entered in mg/dL or mmol/L? If they must be in mg/dL, is there a simple converter tool you’d recommend?
Thanks in advance!
Best regards,
Bas
