Discover How to Install Bookstack on Portainer!
In this tutorial, we’ll walk you through the process, step by step, ensuring you’re set up and ready to go in no time.
It doesnt work cuz there is an error after deployment.
Oops! An Error Occurred
The server returned a “500 Internal Server Error”.
Something is broken. Please let us know what you were doing when this error occurred. We will fix it as soon as possible. Sorry for any inconvenience caused."
I have changed APP_KEY. all the rest is by default in compsoe file - as u set.
i used portainer to fetch logs. The issue was with user permissions UID GUID
Our company is using opensuse(sles) so its customized a bit. Wasnt aware of that.
