How to install Dashdot on CasaOS using BigBearCasaOS
Discover How to Install Dashdot on CasaOS using our App Store BigBearCasaOS! :sparkles: In this tutorial, we’ll walk you through the process, step by step, ensuring you’re set up and ready to go in no time.
Dashdot: dash. (or dashdot ) is a modern server dashboard, running on the latest tech, designed with glassmorphism in mind. It is intended to be used for smaller VPS and private servers.
Is there a way to get my drives to show up ion Dashdot on Casaos?
I’m having the same issue as Casper from a year ago. I follow the instructions and I end up having Dashdot recognize the SSD and the 6x hard drives I have installed, but Dashdot can’t track anything because of a “No mount found” error. I also tried downloading and installing the version from the Big Bear repo and ran into the same issue.
