Greetings my dear friend, thank you for all the content you share, which is of high quality. I would like to know if you are going to include in your material the methods to install at home: lamp or, failing that, a ubuntu that has persistent directories and that can be accessed from the outside to install a web site labpratorium. in advance thank you very much for everything you share with us.
Hello, thanks, and I’m glad you like the content. You would need to containerize the LAMP services, push them to a registry, and then create a Docker Compose file for the Docker Image.
