I’ll guide you through the process of installing Speedtest Tracker 2 step by step on Portainer.
Speedtest Tracker 2: Speedtest Tracker is a self-hosted internet performance tracking application that runs speedtest checks against Ookla’s Speedtest service.
It does not work on raspberry pi because the image, more precisely “:latest” is not made for raspberry pi pocesor which is arm.
failed to deploy a stack: speedtest-tracker Pulling db Pulling no matching manifest for linux/arm/v8 in the manifest list entries
Or if i change latest with arm this is the error:
failed to deploy a stack: speedtest-tracker Pulling db Pulling speedtest-tracker Error db Error Error response from daemon: manifest unknown
You need to install a 64-bit operating system instead of a 32-bit one. This is typically the cause of the error. Please don’t hesitate to respond with additional logs and details if this doesn’t resolve the issue.
