I’ll guide you through the process of installing Unifi Network Application step by step on Portainer.
Maybee somebody can help me, im running portainer at a virtualized debian 12.
The bash script fails, gives me “Error downloading the file. Check your Internet connection or the URL.”
I have make this file/script myself, but i dont seems to be executed.
I was trying to deploy the stack, it goes ok, but with mongodb 6.0.11, the db container, gives an error “requires a CPU with AVX support”
If i remove everything, and deployed with mongo 4.4.7, the db container gives me “error”:“UserNotFound: Could not find user "unifi" for db "unifi"”}
I will be happy for your help ![]()
- Check Internet Connectivity: Make sure your Debian system has proper internet access. You can test this by running
ping google.comor a similar command. - Verify the URL: Ensure that the URL in your script is correct and accessible. You can test this by trying to access the URL from a browser or using
curlorwgetfrom the command line.
Did you run the script before installing unifi network application?
Thanks for your reply!
I already tested internet, i can ping google, both IP and domain.
If i open the link to run.sh in a browser, on the portainer host, its give me the raw file, where it should create the db user, and gives it permission.
Yes the script was runned, before deploying and start of the containers, i have also remove the containers, images, unused volumes several times.
Have you tried running the curl command by itself?
curl -L "https://raw.githubusercontent.com/bigbeartechworld/big-bear-video-assets/main/how-to-install-unifi-network-application-on-portainer/init-mongo.js" -o "/DATA/AppData/unifi-network-application/db/init-mongo.js"
Also, you can download the contents of ini-mongo.js and create the file:
Then use nano to create the file or vim.
Thanks again, for helping me ![]()
Yes, i also tryed this ways, altso manually, i think maybee i will try and fresh installation without old deploys, because i’ve got the feeling, somethings i saved from the many tries that I have done
t={“$date”:“2024-01-18T17:46:00.283+00:00”} s=I c=ACCESS id=20249 ctx=conn477095 msg=Authentication failed attr={“mechanism”:“SCRAM-SHA-256”,“speculative”:true,“principalName”:“unifi”,“authenticationDatabase”:“unifi”,“remote”:“172.19.0.3:57902”,“extraInfo”:{},“error”:“UserNotFound: Could not find user "unifi" for db "unifi"”}
I am getting an error when running the docker-compose-unifi.yml. “Deployment error
failed to deploy a stack: unifi-network-application Pulling unifi-db Pulling unifi-network-application Error no matching manifest for linux/arm/v8 in the manifest list entries” is the error.
I’m running Portainer 2.19.5 on a Pi4 running bookworm Pi OS. I don’t see how to point to the correct manifest. Any help would be appreciated. Thanks.
Seems that Mongodb needs to be version 4.4 and most are not recommending running this on a Pi4 compute module.
This is being worked on at:
