Hello guys! ![]()
I am searching to snag a new laptop for graphic design and could use some pointers from this awesome community! I want to work with programs like Photoshop, coral draw, adobe and Illustrator and sometimes even dabble in 3D rendering.
Here is what I’m after:
- I needs a strong processor and plenty of RAM to handle big files and keep things running smooth when I have a bunch of stuff open at once.
- Super important to have accurate colors and a crisp resolution for my work. Ideally a 15-inch screen, but open to others if they’re top-notch quality.
- Solid-state drive for sure! Faster boot times and file access are a must. 512GB would be great, but 1TB would be amazing.
- While I work from my desk most of the time, I travel sometimes. So, something on the lighter side with decent battery life would be ideal.
- Willing to invest in a good machine, but aiming to keep it under $2,000 if possible.
I have been checking out Dells, Apples, and ASUSes, but open to other brands too! Any recommendations based on your experiences would be fantastic. I also check this: https://community.bigbeartechworld.com/t/dear-big-bear-i-need-your-help-with-nextcloudsalesforce-developer But I have not found any solution. Could anyone suggest the best solution for this.
Thanks in advance! ![]()
Respected community member ![]()
