ok, I have been able to successfully install Immich to my MainSSD storage volume. Everything seems to runt here just fine. However, no matter what I do, the storage template insists on putting files here
UPLOAD_LOCATION/library/admin/…..
I created an upload_location entry in the compose yaml file as I did the custom install yet it does not pick up that location ( i didnt think it would work but had to try)
How do i get it to use the my preferred location
/media/MainSSD/Immich/upload as the base location. I was unable to find the .enve file and not sure where else to turn..
I want to use the Storage template as i want to keep the original images fine names when i upload, i just want them stored on my MainSSD storage and not in
i can manage my way around a terminal prompt but dont know enough otherwise to fix this and Ive not been able to find anything that works through googles help.
Thanks
Robert
