Issues with Tududi
Hi
Hate to be the one to keep having issues, I installed tududi eager to give it a go, but the container seems to be in a constant state of restarting and never seems to be ready and is unhealthy.
  1. if I try to inspect the logs or look at the container it returns “no such container xxxxxxxx” error.
  2. Casa also does this if I uninstall it.
I have had a look at the settings and nothing seems a miss, I did try changing its port but that seems to have no effect.
Any guidance would be appreciated
Thanks
Hello, can you install Dozzle and turn on stopped containers in the settings?
Let me know what the logs say. Just to make sure nothing broke, I went ahead and installed it real quick, fresh, and it worked.
Hi
Thanks for the fast response, I have done as you requested it says format error. Im running it on a pi (sorry should have mentioned that at first) but usually incompatible apps show as such. the error for the container simply says format error
Hello, it looks like they don’t build for Arm64 anymore.
https://hub.docker.com/r/chrisvel/tududi/tags
Pull Request for removing arm64:
I can look at supporting the last build for Arm64, or it is available for AMD64. Also could look into adding it to big-bear-docker-images.
Thats a shame, thanks for your help. May have to bite the bullet and grt a zima blade/board
