Last Updated: 2022-08-08
Boxinvy is an inventory management tool that enables you to inventory a wide range of items, including your home, RV, business, or anything else. It’s specifically designed to help you organize your belongings for insurance purposes, with features such as content and structural cost tracking.
By assigning a cost to a box or individual item, Boxinvy can itemize all of the contents within that location or container and determine the total value of the location, box, or item based on its structural and content costs. This means that you can easily and accurately track the value of your belongings, and have a clear understanding of their worth for insurance purposes.
Boxinvy’s ability to itemize everything is particularly useful for insurance claims as it ensures that you’re accurately compensated for any loss or damage. Additionally, the platform makes it easy to track and manage your inventory, providing you with peace of mind knowing that you have a complete and detailed record of all your possessions.
Locations
Locations are the highest level of organization within Boxinvy’s inventory management tool, and they serve as a container that holds all of your boxes and individual items. They’re intended to be used to organize your belongings by physical location, such as your home, business, or car.
In order to make the most of Boxinvy’s organizational features, it’s recommended that you use locations to group together all of the boxes and items that are located in a specific area. For example, you might create a location for your home and then create boxes within that location to represent each room.
Using locations in this way ensures that your inventory is organized and easy to navigate, making it simple to find and manage individual items as needed. Additionally, it can be very useful when you need to make a claim on your insurance as it provides a clear and accurate record of all your belongings in each location.
Boxes
Boxes in Boxinvy’s inventory management tool are used to represent specific areas within a location. They are positioned just under the location level and can be used to represent anything from a room to a specific section of your business or car.
Boxinvy allows you to create an unlimited number of box levels within each location. This means you can create as many layers of organization as you need to keep track of your belongings.
Each box can contain an unlimited number of items, which makes it easy to group together similar or related items. For example, you might create a box for kitchen utensils or a box for electronics accessories. This helps to keep your inventory organized and makes it simple to locate and manage specific items when needed.
By using boxes to organize your belongings, you can create a hierarchical structure that makes it easy to navigate your inventory and find specific items quickly. Additionally, it can be very useful when you need to make an insurance claim, as it provides a clear and detailed record of the contents of each box within a specific location.
Items
In Boxinvy’s inventory management tool, an item is a standalone object that represents a single entity. An item should not contain any other objects or be used to represent a group of related items.
For example, a laptop or a smartphone would be considered individual items within the inventory management tool, rather than a collection of accessories or components. By representing each item as a standalone object, you can create a more detailed and accurate record of your belongings, which can be very useful when making an insurance claim.
If you have a group of related items, it’s recommended that you create a box and place those items within it. This helps to keep your inventory organized and makes it easier to locate specific items when needed.
By using boxes and items in this way, you can create a hierarchical structure that provides a clear and detailed record of all of your belongings. This makes it easier to manage and track your inventory, and can be very useful when you need to make an insurance claim or when you’re looking for specific items within your inventory.
Moving boxes and items
With Boxinvy’s inventory management tool, organizing your belongings is made easy thanks to its hierarchical structure of locations, boxes, and items. However, if you need to move things around within your inventory, it’s important that the process is also easy and intuitive.
To make it easy to move items and boxes around within your inventory, Boxinvy provides a simple and intuitive process. You can move a single box or item by accessing the “actions” list within the app and selecting the “move” option. This will allow you to easily reposition boxes and items as needed, without the need for complicated and time-consuming processes.
This feature is particularly useful if you’re making changes to your physical space or need to reorganize your inventory for any reason. With Boxinvy, you can easily move things around within your inventory to reflect changes in your physical space or organizational needs.
Overall, the ability to easily move boxes and items within your inventory is an essential feature of any effective inventory management tool. Boxinvy makes it easy to keep your inventory up-to-date and organized, providing you with peace of mind knowing that you have an accurate and detailed record of all your belongings.
Single Move
In Boxinvy’s inventory management tool, there are two ways to move items and boxes within your inventory. The first option is to move items manually, which involves selecting the item or box you wish to move and then selecting the new location where you want to move it. This can be done by clicking on the “move” option in the actions list.
The second option is to use a QR code to move items and boxes. This feature allows you to scan a QR code using your mobile device, which will automatically move the item or box to a new location within your inventory.
To use the QR code feature, you’ll need to print out QR codes for each location and box within your inventory. When you need to move an item or box, simply scan the QR code for the new location, and the item or box will be automatically moved to that location.
The QR code feature is a convenient way to quickly move items and boxes within your inventory, without the need for manual entry or selection. This feature is particularly useful if you have a large inventory or if you frequently need to move items around within your inventory.
Multi Select
When you click “Select Item”, a topbar should appear.
With the multi select, you can move and clone entities.
Convenient Holding Area for Items
When we were creating Boxinvy’s inventory management tool, we realized that it can be confusing to keep track of where each item is going when you’re organizing your inventory. That’s why we created a special “holding area” within the app.
The holding area is a temporary location where you can place items that you’re not sure where to store. It’s a place where you can keep these items until you decide where they should go. This can be particularly helpful when you’re first getting started with organizing your inventory or when you’re in the middle of reorganizing your space.
The holding area is a convenient way to keep track of items that don’t yet have a specific location within your inventory. It allows you to quickly move items out of the way so that you can focus on organizing the rest of your belongings. And when you’re ready to assign a location to an item, you can easily move it out of the holding area and into its new home within your inventory.
Overall, the holding area is a helpful tool that can make it easier to organize your belongings within Boxinvy’s inventory management tool. It provides a temporary storage location for items that don’t yet have a specific location, allowing you to focus on organizing your inventory in a way that works best for you.
How do you move an item from the holding area?
You may need to move items from the holding area to their new location. There are two ways to do this within the app.
The first method involves going to the item that you want to move in the holding area and selecting “move item” from the actions list. This will allow you to select the new location or box where you want to move the item.
The second method involves going directly to the box where you want to add the item and clicking on the box. This will open the box and allow you to see its contents. You can then click on the “add item” option and select the item that you want to add to the box.
Both of these methods are straightforward and easy to use, and they allow you to quickly move items from the holding area to their new location within your inventory. By providing two different options, Boxinvy makes it easy to choose the method that works best for you and your specific inventory organization needs.
Simply click the item to move it out of the holding area and under the box.
QR Codes
QR codes are an important feature of Boxinvy’s inventory management tool. While they’re not required, they can significantly speed up the inventorying process and make it easier to move and clone items within your inventory.
When you use QR codes in Boxinvy, you can add a unique code to each location, box, or item in your inventory. This code can then be scanned using your mobile device, which will automatically take you to the location, box, or item within the app.
This feature is particularly useful when you’re moving items within your inventory or when you need to quickly clone an item. Instead of manually searching for the location or box where the item is located, you can simply scan the QR code and go directly to the item. This saves time and makes the inventorying process much more efficient.
You can add as many QR codes as you want to locations, boxes, and items within your inventory. This means that you can use them to organize your inventory in a way that works best for you. For example, you might use QR codes to quickly locate items within a specific room or area of your home or business.
Overall, QR codes are a powerful tool that can make the inventorying process faster and more efficient. By using QR codes in Boxinvy, you can easily keep track of all of your belongings and ensure that you have an accurate and up-to-date record of everything in your inventory.
QR Code Comparison Utility
QR codes are a powerful feature that allows you to quickly and easily locate items within your inventory. However, if you have a box with a QR code on both the lid and the bottom, it can be challenging to determine which lid goes with which box if the lids are separated from their corresponding boxes.
To solve this problem, Boxinvy has a utility built in to compare QR codes and see if they match. This means that you can scan the QR code on each lid and compare it to the QR code on the corresponding box to determine which lid goes with which box.
By using this utility, you can easily match lids to their corresponding boxes, even if the lids are separated from their boxes. This helps to ensure that your inventory is accurate and up-to-date, and that you can quickly locate any item within your inventory.
Overall, the QR code comparison utility is a powerful tool that makes it easy to manage your inventory, even when dealing with separated lids and boxes. With this feature, you can be confident that your inventory is accurate and well-organized, allowing you to quickly and easily find any item within your inventory.
You would scan the QR Code at the bottom of the box and use that as your primary to compare several secondary QR Codes to.
To match separated lids with their corresponding boxes in Boxinvy’s inventory management tool, simply scan the QR codes on the lids until you find a match with the primary code on the box. Thanks to Boxinvy’s ability to link numerous QR codes to boxes, this is a simple and efficient way to keep your inventory organized and save time.
In conclusion, Boxinvy is a powerful inventory management tool that can make keeping track of your belongings easier and more efficient. Its intuitive interface, hierarchical structure, and powerful features like QR codes and a holding area make it easy to organize your inventory and ensure that you have an accurate and up-to-date record of your belongings.
Whether you’re using Boxinvy for your home, RV, business, or any other inventory need, it’s designed to make the inventorying process simple and efficient. And if you ever have any questions or problems while using Boxinvy, you can easily contact BigBearSupport in the bottom right of the screen.
You can try Boxinvy for free on the web, iOS, or Android, and experience its powerful features and easy-to-use interface for yourself. So why not give it a try and see how it can simplify your inventory management process today?
