Metube SSL: certificate _verify_failed
Just wondering if anyone other then myself is having this problem? Is so how did you resolve it?
This use to work very well until the zimaos update then it started giving this error. I started moving the version from stable to latest and restarted. No change. Then I changed it back and restarted. No change.
Metube 01/05/2025
Zimaos 1.4.1
