Hello BigBear Community,
I’m seeking help with setting up the Gramps Genealogy Program in Docker behind a Nginx reverse proxy with a Let’s Encrypt SSL certificate on my Ubuntu Server 24.04. While Docker is installed and ready to go, I’m finding the documentation a bit unclear, especially when it comes to getting both the Gramps application running properly in Docker and securing it with Nginx and Let’s Encrypt. The gramps program is at Gramps – Free Genealogy Software
Here are the steps I’ve tried so far:
- Installed Docker on Ubuntu Server 24.04.
- Followed the Gramps Docker setup, but didn’t get it fully operational.
- Got stuck when trying to configure Nginx as a reverse proxy to access Gramps securely.
Could anyone kindly provide a clear, step-by-step guide to help me achieve the following?
- Properly setting up the Gramps program inside Docker.
- Configuring Nginx to reverse proxy the Gramps app.
- Securing everything with a Let’s Encrypt SSL certificate.
I’d greatly appreciate any insights, examples, or detailed instructions to help me complete the setup or a video on the install process would be awesome. Thanks in advance!
