so EmulatorJS has been updated and so the web emulator shows outdated and doesn’t allow you to play
Just to add to this, a recent update was pushed by EmuJS devs that has unexpectedly affected the way we grab the cores, so this means anyone on your version of RomM will still have all the capabilities of RomM but the web emulator, which quite a few people find crucial.
I don’t know how you grab the images, but a quick alpha image with EmuJS fixes and some nice enhancements has been pushed which if EmuJS makes a change like this again, RomM can handle it.
So in order to fix you need to somehow pull the alpha image for 3.7, we feel this will be the only time you need to pull an alpha image but right now 3.6 web emulation does not work.
If you want to discuss more drop by our discord, thanks for the project though and helping people get easy access to RomM.
Thank you for clarifying. Don’t normally push an alpha image, but since a key feature is broken, I’ll push the change.
This pull request should fix your issue. Let me know if it does.
You’re welcome! Feel free to make a pull request if you see something needs changed. Trying to keep the app store up to date as much as possible.
