Nextcloud and MariaDB error
Hello I followed the instructions in your MariaDB and Nexcloud video but I keep getting this error when I’m trying to set up Nextcloud for the first time.
Error while trying to create admin user: Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] Operation timed out
What am I doing wrong? The Hardware is not a ZIMAboard, its an AMD APU machine.
Are you installing on zimaOS? I have used this script via Dockge. I just installed today.
version: '3'
  nextcloud_db:
    image: mariadb:10.5
    command: --transaction-isolation=READ-COMMITTED --binlog-format=ROW
    restart: always
      - ./nextcloud-db:/var/lib/mysql
      - MYSQL_ROOT_PASSWORD=123456
      - MYSQL_PASSWORD=adcdef
      - MYSQL_DATABASE=nextcloud
      - MYSQL_USER=nextcloud
  nextcloud:
    image: nextcloud:latest
    ports:
      - 9090:80
    links:
      - nextcloud_db
      - /DATA/AppData/Nextcloud:/var/www/html
      - NEXTCLOUD_DATA_DIR=/var/www/html/data
      - MYSQL_PASSWORD=abcdef
      - MYSQL_HOST=nextcloud_db
    restart: always
Of course, change the passwords.
