Nextcloud loading page stuck
Hi,
I have installed nextcloud on casaos. Everything seems to work but I’m having problem when I try to log in.
If I use my domain (SSL cert with npm) It keeps loading until I refresh the page. I have tried every tutorial on the internet but nothing seems to work. On browser is not a big problem but on smartphone you can’t use the app properly.
Thank you
Hi.
Is it your SSL cert self-signed or Let’s Encrypt?
Thanks for your answer but I ended up to get rid of nextcloud and build my own app as I just needed for one thing xD
