No update for immich?
Hello everyone,
I use casaOS and first installed immich, big-bear version.
Currently, the installed version is 1.137.3 and on GitHub, version 1.138.1 seems to be available.
However, I am not being offered an update to the new version.
Is there a step I am missing?
Thank you for your help!
Bump;
Just switched from iOS to Android
IOS app works fine but android does not due to Server being behind.
App version 1.142.0
Server Version stuck at 1.129.0
+1
My android app is not functioning properly. I’m willing to update manually if BigBear isn’t going to be maintained, but I haven’t found any CasaOS friendly instructions to do so. Any help is appreciated.
BigBearCasaOS is fully maintained right now. I would recommend restarting your CasaOS because there is an outstanding bug that stops apps from being updated. (I’ve let IW know a while ago) Here is the source of truth on what version is available from BigBearCasaOS.
Awesome! Thank you so much. Updated after a restart.
