Hello. I am trying to install obsidian livesync on cosmos, and i obtain a message:
[ERROR] Rolling back changes because of – Container creation error: Error response from daemon: source […]/opt/couchdb/etc/local.ini is not directory.
How can I solve this? I am using default template, unmodified.
Thank you
You need to run the script to generate the file before installing the container.
