Is the 250 doors sub only for 250 a month or is it per day?
I need help with this. I purchased what I thought was the 250/day. Today my 3 guys have knocked about 30 each and they’re being told we’re over quota.
Yes, it is 250 a day. Can you send me your email so I can check on this?
I’ve looked into this for the general system and I did see an issue with the IAP integration. Can you check now to see if it’s fixed? I do apologies for the inconvenience!
Still says we maxed out for the day. Pins are also now showing on the map for doors knocked.
The pins are not showing or they where not showing and now they are? Can you send me a pm with your email so I can check on your team?
Sent you a PM
