Pi-hole unbound
Hi everyone,
I’m trying to make pi-hole unbound act as my DHCP. I deactivated my DHCP from Verizon and turned pi-hole to do DHCP. As soon as it gets activated, I get the following error messages.
  1. systemctl: command not found
  2. DNSMASQ_CONFIG
    I have followed all the possible solutions from restart services, reinstalling pi-hole, manual updates., check in githug, I also use Grok A.I for answers, and nothing has worked. Has anyone seen this issue.
    Any help or guidance would be greatly appreciated. :pensive:
Hello,
Could you provide more info? Your current Docker Compose. Any logs on the container.
So am i… im on t-mobile 5g internet so i am wondering if there is an issue with the configuration… my wror log also says selinux isnt installed…
All my apps are current as of 2 hrs ago
I can share the logs as the portal would not allow me to do it as I’m a newbie :O(
