PiHole on Portainer web GUI not accessible
hello i did these steps i have the container and it shows up as healthy but when i go to the web GUI i get this.
The webpage at http://IPADDRESS:53/ might be temporarily down or it may have moved permanently to a new web address.
I think it has something to do with the port. i ran the command to clear port 53… not sure what i did wrong. Any help would be appreciated!
here are my logs
S2024-07-05T19:07:14.349957966Z s6-rc: info: service s6rc-oneshot-runner: starting
^2024-07-05T19:07:14.351575962Z s6-rc: info: service s6rc-oneshot-runner successfully started
I2024-07-05T19:07:14.351596262Z s6-rc: info: service fix-attrs: starting
T2024-07-05T19:07:14.353630289Z s6-rc: info: service fix-attrs successfully started
P2024-07-05T19:07:14.353648310Z s6-rc: info: service legacy-cont-init: starting
[2024-07-05T19:07:14.355037091Z s6-rc: info: service legacy-cont-init successfully started
D2024-07-05T19:07:14.355085165Z s6-rc: info: service cron: starting
O2024-07-05T19:07:14.356196849Z s6-rc: info: service cron successfully started
P2024-07-05T19:07:14.356348681Z s6-rc: info: service _uid-gid-changer: starting
[2024-07-05T19:07:14.358431152Z s6-rc: info: service _uid-gid-changer successfully started
H2024-07-05T19:07:14.358473354Z s6-rc: info: service _startup: starting
g2024-07-05T19:07:14.368718620Z [i] Starting docker specific checks & setup for docker pihole/pihole
X2024-07-05T19:07:14.368747495Z [i] Setting capabilities on pihole-FTL where possible
Q2024-07-05T19:07:14.372195058Z [i] Applying the following caps to pihole-FTL:
42024-07-05T19:07:14.372223138Z * CAP_CHOWN
?2024-07-05T19:07:14.372229011Z * CAP_NET_BIND_SERVICE
62024-07-05T19:07:14.372232832Z * CAP_NET_RAW
x2024-07-05T19:07:14.375132300Z [i] Ensuring basic configuration by re-running select functions from basic-install.sh
!2024-07-05T19:07:14.375160524Z
N2024-07-05T19:07:14.375168654Z [i] Installing configs from /etc/.pihole…
n2024-07-05T19:07:14.376720950Z [i] Existing dnsmasq.conf found… it is not a Pi-hole file, leaving alone!
�2024-07-05T19:07:14.377706655Z [i] Installing /etc/dnsmasq.d/01-pihole.conf… e[K [✓] Installed /etc/dnsmasq.d/01-pihole.conf
�2024-07-05T19:07:14.382612021Z [i] Installing /etc/.pihole/advanced/06-rfc6761.conf… e[K [✓] Installed /etc/dnsmasq.d/06-rfc6761.conf
!2024-07-05T19:07:14.455777480Z
z2024-07-05T19:07:14.458719586Z [i] Installing latest logrotate script… e[K [✓] Installing latest logrotate script
V2024-07-05T19:07:14.459720032Z [i] Creating empty /etc/pihole/setupVars.conf file.
Y2024-07-05T19:07:14.467069619Z [i] Assigning password defined by Environment Variable
92024-07-05T19:07:14.512563999Z [✓] New password set
82024-07-05T19:07:14.520108193Z [i] Added ENV to php:
C2024-07-05T19:07:14.520799839Z “TZ” => “CDT”,
O2024-07-05T19:07:14.520830304Z “PIHOLE_DOCKER_TAG” => “”,
m2024-07-05T19:07:14.520839123Z “PHP_ERROR_LOG” => “/var/log/lighttpd/error-pihole.log”,
H2024-07-05T19:07:14.520845373Z “CORS_HOSTS” => “”,
V2024-07-05T19:07:14.520851102Z “VIRTUAL_HOST” => “01033f5ab713”,
:2024-07-05T19:07:14.521667871Z [i] Using IPv4 and IPv6
!2024-07-05T19:07:14.522384365Z
p2024-07-05T19:07:14.524965780Z [i] Installing latest Cron script… e[K [✓] Installing latest Cron script
[2024-07-05T19:07:14.525068097Z [i] setup_blocklists now setting default blocklists up:
�2024-07-05T19:07:14.525079846Z [i] TIP: Use a docker volume for /etc/pihole/adlists.list if you want to customize for first boot
X2024-07-05T19:07:14.525138182Z [i] Blocklists (/etc/pihole/adlists.list) now set to:
a2024-07-05T19:07:14.525552720Z https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
X2024-07-05T19:07:14.526584047Z [i] Configuring default DNS servers: 8.8.8.8, 8.8.4.4
Z2024-07-05T19:07:14.530410557Z [i] Applying pihole-FTL.conf setting LOCAL_IPV4=0.0.0.0
M2024-07-05T19:07:14.532619694Z [i] FTL binding to default interface: eth0
=2024-07-05T19:07:14.534467433Z [i] Enabling Query Logging
I2024-07-05T19:07:14.601734823Z [i] Testing lighttpd config: Syntax OK
X2024-07-05T19:07:14.601932016Z [i] All config checks passed, cleared for startup …
B2024-07-05T19:07:14.602750590Z [i] Docker start setup complete
!2024-07-05T19:07:14.602765455Z
W2024-07-05T19:07:14.602772018Z [i] pihole-FTL (no-daemon) will be started as pihole
!2024-07-05T19:07:14.602776470Z
S2024-07-05T19:07:14.603174454Z s6-rc: info: service _startup successfully started
J2024-07-05T19:07:14.603288143Z s6-rc: info: service pihole-FTL: starting
U2024-07-05T19:07:14.604067422Z s6-rc: info: service pihole-FTL successfully started
H2024-07-05T19:07:14.604107789Z s6-rc: info: service lighttpd: starting
S2024-07-05T19:07:14.605300000Z s6-rc: info: service lighttpd successfully started
H2024-07-05T19:07:14.605378210Z s6-rc: info: service _postFTL: starting
S2024-07-05T19:07:14.606478033Z s6-rc: info: service _postFTL successfully started
O2024-07-05T19:07:14.606600493Z s6-rc: info: service legacy-services: starting
f2024-07-05T19:07:14.607097585Z Checking if custom gravity.db is set in /etc/pihole/pihole-FTL.conf
Z2024-07-05T19:07:14.609732219Z s6-rc: info: service legacy-services successfully started
D2024-07-05T19:07:14.625546972Z [i] Creating new gravity database
f2024-07-05T19:07:14.698115682Z [i] Migrating content of /etc/pihole/adlists.list into new database
E2024-07-05T19:07:14.773662325Z [i] Neutrino emissions detected…
U2024-07-05T19:07:14.782746030Z e[K [✓] Pulling blocklist source list into range
!2024-07-05T19:07:14.782777771Z
r2024-07-05T19:07:14.793892506Z [i] Preparing new gravity database… e[K [✓] Preparing new gravity database
r2024-07-05T19:07:14.812532208Z [i] Creating new gravity databases… e[K [✓] Creating new gravity databases
=2024-07-05T19:07:14.817978883Z [i] Using libz compression
!2024-07-05T19:07:14.818010985Z
o2024-07-05T19:07:14.818018969Z [i] Target: https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
a2024-07-05T19:07:18.947382721Z [i] Status: Pending… e[K [✓] Status: Retrieval successful
|2024-07-05T19:07:19.103320763Z [✓] Parsed 165493 exact domains and 0 ABP-style domains (ignored 1 non-domain entries)
D2024-07-05T19:07:19.103354864Z Sample of non-domain entries:
42024-07-05T19:07:19.103359961Z - “0.0.0.0”
!2024-07-05T19:07:19.103363671Z
!2024-07-05T19:07:19.116280736Z
P2024-07-05T19:07:19.169618959Z [i] Building tree… e[K [✓] Building tree
Z2024-07-05T19:07:19.172562458Z [i] Swapping databases… e[K [✓] Swapping databases
K2024-07-05T19:07:19.172591028Z [✓] The old database remains available
2024-07-05T19:07:19.194838773Z [i] Number of gravity domains: 165493 (165493 unique domains) M2024-07-05T19:07:19.201753697Z [i] Number of exact blacklisted domains: 0 K2024-07-05T19:07:19.203029508Z [i] Number of regex blacklist filters: 0 M2024-07-05T19:07:19.204325030Z [i] Number of exact whitelisted domains: 0 K2024-07-05T19:07:19.205600106Z [i] Number of regex whitelist filters: 0 f2024-07-05T19:07:19.212660487Z [i] Cleaning up stray matter... e[K [✓] Cleaning up stray matter !2024-07-05T19:07:19.214365306Z D2024-07-05T19:07:19.222115190Z [✓] FTL is listening on port 53 62024-07-05T19:07:19.275878414Z [✓] UDP (IPv4) 62024-07-05T19:07:19.276541815Z [✓] TCP (IPv4) 62024-07-05T19:07:19.279117456Z [✓] UDP (IPv6) 62024-07-05T19:07:19.279795112Z [✓] TCP (IPv6) !2024-07-05T19:07:19.279803215Z G2024-07-05T19:07:19.281149078Z [i] Pi-hole blocking will be enabled 82024-07-05T19:07:19.284694258Z [i] Enabling blocking <2024-07-05T19:07:19.289050828Z e[K [✓] Pi-hole Enabled !2024-07-05T19:07:19.289496511Z O2024-07-05T19:07:21.181334077Z Pi-hole version is v5.18.2 (Latest: v5.18.3) G2024-07-05T19:07:21.181882812Z web version is v5.21 (Latest: v5.21) K2024-07-05T19:07:21.182563143Z FTL version is v5.25.2 (Latest: v5.25.2) >2024-07-05T19:07:21.183989673Z Container tag is: 2024.06.0 !2024-07-05T19:07:21.184022251Z O2024-07-05T19:17:14.116401577Z s6-rc: info: service legacy-services: stopping Z2024-07-05T19:17:14.230827544Z s6-rc: info: service legacy-services successfully stopped H2024-07-05T19:17:14.230904663Z s6-rc: info: service _postFTL: stopping S2024-07-05T19:17:14.232982417Z s6-rc: info: service _postFTL successfully stopped H2024-07-05T19:17:14.245911389Z s6-rc: info: service lighttpd: stopping 22024-07-05T19:17:14.360120261Z Stopping lighttpd S2024-07-05T19:17:14.395337513Z s6-rc: info: service lighttpd successfully stopped J2024-07-05T19:17:14.395771690Z s6-rc: info: service pihole-FTL: stopping 42024-07-05T19:17:14.400002550Z Stopping pihole-FTL +2024-07-05T19:17:14.401704817Z Terminated U2024-07-05T19:17:14.401993006Z s6-rc: info: service pihole-FTL successfully stopped H2024-07-05T19:17:14.402047723Z s6-rc: info: service _startup: stopping S2024-07-05T19:17:14.402958107Z s6-rc: info: service _startup successfully stopped P2024-07-05T19:17:14.403009317Z s6-rc: info: service _uid-gid-changer: stopping [2024-07-05T19:17:14.403731284Z s6-rc: info: service _uid-gid-changer successfully stopped D2024-07-05T19:17:14.403746595Z s6-rc: info: service cron: stopping .2024-07-05T19:17:14.405851372Z Stopping cron O2024-07-05T19:17:14.406653959Z s6-rc: info: service cron successfully stopped P2024-07-05T19:17:14.406685602Z s6-rc: info: service legacy-cont-init: stopping [2024-07-05T19:17:14.420810661Z s6-rc: info: service legacy-cont-init successfully stopped I2024-07-05T19:17:14.420835796Z s6-rc: info: service fix-attrs: stopping T2024-07-05T19:17:14.421714229Z s6-rc: info: service fix-attrs successfully stopped S2024-07-05T19:17:14.421737245Z s6-rc: info: service s6rc-oneshot-runner: stopping ^2024-07-05T19:17:14.422717067Z s6-rc: info: service s6rc-oneshot-runner successfully stopped t2024-07-05T19:17:16.935663879Z s6-linux-init-shutdown: fatal: unable to talk to shutdownd: Operation not permitted S2024-07-05T19:17:20.454196438Z s6-rc: info: service s6rc-oneshot-runner: starting ^2024-07-05T19:17:20.482357350Z s6-rc: info: service s6rc-oneshot-runner successfully started I2024-07-05T19:17:20.482518180Z s6-rc: info: service fix-attrs: starting T2024-07-05T19:17:20.486618779Z s6-rc: info: service fix-attrs successfully started P2024-07-05T19:17:20.486677209Z s6-rc: info: service legacy-cont-init: starting [2024-07-05T19:17:20.490512325Z s6-rc: info: service legacy-cont-init successfully started D2024-07-05T19:17:20.490555754Z s6-rc: info: service cron: starting O2024-07-05T19:17:20.492562574Z s6-rc: info: service cron successfully started P2024-07-05T19:17:20.492638745Z s6-rc: info: service _uid-gid-changer: starting [2024-07-05T19:17:20.495131728Z s6-rc: info: service _uid-gid-changer successfully started H2024-07-05T19:17:20.495149458Z s6-rc: info: service _startup: starting g2024-07-05T19:17:20.621473767Z [i] Starting docker specific checks & setup for docker pihole/pihole X2024-07-05T19:17:20.621509623Z [i] Setting capabilities on pihole-FTL where possible Q2024-07-05T19:17:20.641394398Z [i] Applying the following caps to pihole-FTL: 42024-07-05T19:17:20.641435091Z * CAP_CHOWN ?2024-07-05T19:17:20.641462113Z * CAP_NET_BIND_SERVICE 62024-07-05T19:17:20.641470518Z * CAP_NET_RAW x2024-07-05T19:17:20.673379381Z [i] Ensuring basic configuration by re-running select functions from basic-install.sh !2024-07-05T19:17:20.673437626Z N2024-07-05T19:17:20.673450312Z [i] Installing configs from /etc/.pihole... n2024-07-05T19:17:20.695681920Z [i] Existing dnsmasq.conf found... it is not a Pi-hole file, leaving alone! �2024-07-05T19:17:20.731738640Z [i] Installing /etc/dnsmasq.d/01-pihole.conf... e[K [✓] Installed /etc/dnsmasq.d/01-pihole.conf �2024-07-05T19:17:20.786689501Z [i] Installing /etc/.pihole/advanced/06-rfc6761.conf... e[K [✓] Installed /etc/dnsmasq.d/06-rfc6761.conf !2024-07-05T19:17:21.184578941Z L2024-07-05T19:17:21.187429118Z [i] Installing latest logrotate script... U2024-07-05T19:17:21.187468270Z [i] Existing logrotate file found. No changes made. Y2024-07-05T19:17:21.213497848Z [i] Assigning password defined by Environment Variable 92024-07-05T19:17:21.250140473Z [✓] New password set 82024-07-05T19:17:21.257759777Z [i] Added ENV to php: C2024-07-05T19:17:21.258396457Z "TZ" => "CDT", O2024-07-05T19:17:21.258417806Z "PIHOLE_DOCKER_TAG" => "", m2024-07-05T19:17:21.258422787Z "PHP_ERROR_LOG" => "/var/log/lighttpd/error-pihole.log", H2024-07-05T19:17:21.258426563Z "CORS_HOSTS" => "", V2024-07-05T19:17:21.258429962Z "VIRTUAL_HOST" => "01033f5ab713", :2024-07-05T19:17:21.259067807Z [i] Using IPv4 and IPv6 !2024-07-05T19:17:21.259779439Z p2024-07-05T19:17:21.262207658Z [i] Installing latest Cron script... e[K [✓] Installing latest Cron script [2024-07-05T19:17:21.262284976Z [i] setup_blocklists now setting default blocklists up: �2024-07-05T19:17:21.262295799Z [i] TIP: Use a docker volume for /etc/pihole/adlists.list if you want to customize for first boot X2024-07-05T19:17:21.262382107Z [i] Blocklists (/etc/pihole/adlists.list) now set to: a2024-07-05T19:17:21.262730348Z https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts j2024-07-05T19:17:21.263916076Z [i] Existing DNS servers detected in setupVars.conf. Leaving them alone Z2024-07-05T19:17:21.265268087Z [i] Applying pihole-FTL.conf setting LOCAL_IPV4=0.0.0.0 M2024-07-05T19:17:21.275381658Z [i] FTL binding to default interface: eth0 =2024-07-05T19:17:21.278774004Z [i] Enabling Query Logging I2024-07-05T19:17:21.463487516Z [i] Testing lighttpd config: Syntax OK X2024-07-05T19:17:21.463682721Z [i] All config checks passed, cleared for startup ... B2024-07-05T19:17:21.463725871Z [i] Docker start setup complete !2024-07-05T19:17:21.463737517Z W2024-07-05T19:17:21.463759931Z [i] pihole-FTL (no-daemon) will be started as pihole !2024-07-05T19:17:21.463764990Z S2024-07-05T19:17:21.464507090Z s6-rc: info: service _startup successfully started J2024-07-05T19:17:21.464539372Z s6-rc: info: service pihole-FTL: starting U2024-07-05T19:17:21.465551357Z s6-rc: info: service pihole-FTL successfully started H2024-07-05T19:17:21.465593994Z s6-rc: info: service lighttpd: starting S2024-07-05T19:17:21.466429311Z s6-rc: info: service lighttpd successfully started H2024-07-05T19:17:21.466533043Z s6-rc: info: service _postFTL: starting S2024-07-05T19:17:21.467714103Z s6-rc: info: service _postFTL successfully started O2024-07-05T19:17:21.467880127Z s6-rc: info: service legacy-services: starting f2024-07-05T19:17:21.468387419Z Checking if custom gravity.db is set in /etc/pihole/pihole-FTL.conf Z2024-07-05T19:17:21.470680775Z s6-rc: info: service legacy-services successfully started E2024-07-05T19:17:25.617462807Z [i] Neutrino emissions detected... U2024-07-05T19:17:25.673912344Z e[K [✓] Pulling blocklist source list into range !2024-07-05T19:17:25.673981964Z r2024-07-05T19:17:25.700714358Z [i] Preparing new gravity database... e[K [✓] Preparing new gravity database r2024-07-05T19:17:25.715236648Z [i] Creating new gravity databases... e[K [✓] Creating new gravity databases =2024-07-05T19:17:25.979128607Z [i] Using libz compression !2024-07-05T19:17:25.979155164Z o2024-07-05T19:17:25.979160741Z [i] Target: https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts a2024-07-05T19:17:26.168559495Z [i] Status: Pending... e[K [✓] Status: Retrieval successful |2024-07-05T19:17:26.347507655Z [✓] Parsed 165493 exact domains and 0 ABP-style domains (ignored 1 non-domain entries) D2024-07-05T19:17:26.347551107Z Sample of non-domain entries: 42024-07-05T19:17:26.347556216Z - "0.0.0.0" !2024-07-05T19:17:26.347560084Z <2024-07-05T19:17:26.362547658Z [i] List stayed unchanged !2024-07-05T19:17:26.370489413Z P2024-07-05T19:17:26.421007805Z [i] Building tree... e[K [✓] Building tree Z2024-07-05T19:17:26.433956318Z [i] Swapping databases... e[K [✓] Swapping databases K2024-07-05T19:17:26.433978459Z [✓] The old database remains available 2024-07-05T19:17:26.456105459Z [i] Number of gravity domains: 165493 (165493 unique domains)
M2024-07-05T19:17:26.462466968Z [i] Number of exact blacklisted domains: 0
K2024-07-05T19:17:26.463883488Z [i] Number of regex blacklist filters: 0
M2024-07-05T19:17:26.465223988Z [i] Number of exact whitelisted domains: 0
K2024-07-05T19:17:26.466466534Z [i] Number of regex whitelist filters: 0
f2024-07-05T19:17:26.515536034Z [i] Cleaning up stray matter… e[K [✓] Cleaning up stray matter
!2024-07-05T19:17:26.605714180Z
D2024-07-05T19:17:26.618036516Z [✓] FTL is listening on port 53
62024-07-05T19:17:26.639656847Z [✓] UDP (IPv4)
62024-07-05T19:17:26.640559226Z [✓] TCP (IPv4)
62024-07-05T19:17:26.643379376Z [✓] UDP (IPv6)
62024-07-05T19:17:26.644061285Z [✓] TCP (IPv6)
!2024-07-05T19:17:26.644069410Z
D2024-07-05T19:17:26.645399130Z [✓] Pi-hole blocking is enabled
!2024-07-05T19:17:26.645747583Z
O2024-07-05T19:17:29.319732551Z Pi-hole version is v5.18.2 (Latest: v5.18.3)
G2024-07-05T19:17:29.321323198Z web version is v5.21 (Latest: v5.21)
K2024-07-05T19:17:29.322427151Z FTL version is v5.25.2 (Latest: v5.25.2)
>2024-07-05T19:17:29.323923816Z Container tag is: 2024.06.0
!2024-07-05T19:17:29.323948254Z
Hello and welcome to the Big Bear Community.
You would need to go to: http://IPADDRESS:7300 to see the UI. Port 53 is the DNS port.
http://IPADRESS:7300/
i get access forbidden… not sure why i see in the logs that it is working for PiHole…
403 forbidden… im so dumb.
I looked through the Pihole Forums and found out i needed to add /admin to the IP Address and port number so it would be IPADDRESS:7300/admin
Awesome! No reason to call yourself dumb; everybody is learning :slight_smile: I’m glad it’s working!
