So, Pocketbase is an open-source backend for your next SaaS and mobile app, all in one file.
I wanted to add it to BigBearCasaOS, but there was no official Docker image available. So, I started the ‘big-bear-docker-images’ repository to store all of the Docker images that we create and maintain for BigBearCommunity.
This image is built on Alpine, making it lightweight.
Pocketbase Paths
- http://[YOUR_IP]:8090 - if pb_public directory exists, serves the static content from it (html, css, images, etc.)
- http://[YOUR_IP]:8090/_/ - Admin dashboard UI
- http://[YOUR_IP]:8090/api/ - REST API
Docker Compose
# Specify the version of Docker Compose being used
version: '3.8'
# Define the services that will run in the Docker Compose environment
# Define the "pocketbase" service
pocketbase:
# Use the specified Docker image for this service
image: bigbeartechworld/big-bear-pocketbase:0.19.1
# Map port 8090 on the host to port 8090 in the container
ports:
- "8090:8090"
# Mount a volume from the host to the container
# This is used to persist data between container runs
volumes: /DATA/AppData/big-bear-pocketbase/data:/app/data
