Maybe this will help other people.
Why can’t you get the wings for big-bear-casaos to work?
I really dont know it was the only way that worked for me
Can you try it again. I made some changes.
I have the same issue. The panel works fine. Then I installed Wings to get my node working, but for some reason, wings didn’t create the .yml file, so I had to create it. I’m not sure if this is normal. Then I copy the configuration from the node, put it in the .yml file, and restart both the panel and wings, and the wings create additional lines in the .yml file, but when I go to check the panel, it still says the node is down. Plz make a youtube video or something to help fix this issue
Also, why is the video down?
Oh wait i think i took down the wrong vid mb
Im reposting it rn btw but you still got the issues bc i apparently updated the docker compose
Alright thank you so much
Yes I still have the same issue ima trying and see if your video will help in a little bit thx so much for reposting it tho ![]()
