The data should be in /DATA/AppData/*
Thanks that also fixed it for me, by default it was
/DATA/AppData/big-bear-pterodactyl-wings/lib - /var/lib/pterodactyl
Is there a way of hiding these now when I create servers?
Looks like you cant hide it.
I was then having problems with bind to tcp4 192.168.1.x, and only āspongeā minecraft was working.
Dont know why Vanilla and others dont auto download. āYour server is in failed condition, please remove and re-create serverā
Hm interesting, installing pterodactyl on a seperate vm is deffo a better option. I have tested that but it uses more resources than when I add it into casaos.
So for now since we canāt hide it, I have set it to the weburl of the server. And gave it a logo. I guess itās okay this way.
Do you have any idea what rebuilding or exporting as compose will have as effect on it? Will it brick it?
I try to rebuild it. Pterodactyl did just make a new one, when you start server.
Hm I changed this yesterday and the server I created was able to find itās files after this change.
But now when I create a new server, it fails every time. I gave it a few minutes but the installation state remains active and I donāt get the option to toggle the status away.
However, the server seems to be working.
I just canāt really manage itās settings or files now bc of the installation status.
This server is in a failed install state and cannot be recovered. Please delete and re-create the server.
I have added the volume /DATA/AppData/big-bear-pterodactyl-wings/lib
again that I changed yesterday to fix the server finding itās files. But the issue remains.
EDIT:
I remembered to have changed the node name. I did copy paste the config for wings again and itās working again.
However, like yesterday when it was working, the install status never ends. I need to go and click Toggle install status. Do you experience the same?
EDIT 2:
Sorry hahaha I left it at that status and now itās back to failed state and I canāt get access to the toggle anymore. Idk if other people also experience this and if the solution is to use the toggle as soon as it appears and not wait for it to time out or smt?
Iāve never seen a way to hide the apps that are legacy.
Still have this on my todo list to look into. Just have to find some time.
Soo did you manage to figure it out because am at the same issue as shown here⦠stays stuck at installing stage
Hello, i can“t login into pterodactyl panel, how i can create the user and password or what is the default credentials
Did you run this script?
Did you get it installed? Just saw this.
Yes but is not working, i reinstalled it and it works, thanks
Awesome! Iām glad itās now working. If you have any steps to share on how you got it to work please provide them here and it might help others.
So should the bottom 3 volumes supposed to be:
/DATA/AppData/big-bear-pterodactyl-wings/logs - /var/log/pterodactyl
/DATA/AppData/big-bear-pterodactyl-wings/var/lib/pterodactyl - /var/lib/pterodactyl
/DATA/AppData/big-bear-pterodactyl-wings/var/lib/pterodactyl/volumes - /var/lib/pterodactyl/volumes
Originally it seems like there are only 7 volumes, so do I have to add one more and edit the other 2 volumes?
Hi! I didnāt really understand, I have the same problem with Node, I didnāt really understand how to solve it
Iām having a similar problem with Pterodactyl node not connecting, and this is what the network says. Is there anything conflicting?
Hello, i just come because i have a similar problem with wings
INFO: [Sep 14 12:35:31.959] writing log files to disk path=/var/log/pterodactyl/wings.log
____
__ Pterodactyl _____/___/_______ _______ ______
\_____\ \/\/ / / / __ / ___/
\___\ / / / / /_/ /___ /
\___/\___/___/___/___/___ /______/
/_______/ 1.11.13
Copyright Ā© 2018 - 2024 Dane Everitt & Contributors
Website: https://pterodactyl.io
Source: https://github.com/pterodactyl/wings
License: https://github.com/pterodactyl/wings/blob/develop/LICENSE
This software is made available under the terms of the MIT license.
The above copyright notice and this permission notice shall be included
in all copies or substantial portions of the Software.
INFO: [Sep 14 12:35:31.959] loading configuration from file config_file=/etc/pterodactyl/config.yml
INFO: [Sep 14 12:35:31.959] configured wings with system timezone timezone=UTC
INFO: [Sep 14 12:35:31.959] configured system user successfully gid=988 uid=988 username=pterodactyl
INFO: [Sep 14 12:35:31.961] fetching list of servers from API
INFO: [Sep 14 12:35:32.262] processing servers returned by the API total_configs=0
INFO: [Sep 14 12:35:32.262] finished processing server configurations duration=104.608µs
INFO: [Sep 14 12:35:32.263] creating missing pterodactyl0 interface, this could take a few seconds...
FATAL: [Sep 14 12:35:32.264] failed to configure docker environment error=Error response from daemon: invalid pool request: Pool overlaps with other one on this address space
Stacktrace:
and the panel have no error
iām totaly newbie with docker
I cant figure out the username and password i did do the script before installing the app but i cant figure it out
same bro did u found it
