Hello!
I’d be really happy to see a CasaOS setup for Coolify, a way to self-host web apps with buit-in local build CI/CD.
Thank you!
Hello!
Thank you!
Awesome suggestion. Coolify is a cool product. I was thinking of starting a series on it!
@dragonfire1119 That would be so cool! Id definitely be interested to watch, the tool is definitely trending and going up in awareness.
I’d love to get some help for CasaOS, as it may not be that easy to let Coolify deploy external containers, I don’t really know.
Thanks a lot for your great content!
that would be awesome !
I would suggest using a VPS for this if you’re going to use it. You can still have it in CasaOS but I hosting it at home might be tricky.
