Request for AzuraCast!
Azuracast is a Web Radio station Application that you can Play music to a broad audiance world wide or DJ to that same audiance. would love to see this added to casaos as i have zero knowledge on how to do it myself.
Do you have more information and links on this app?
Is this the one you’re thinking about:
yes thats the one. they do have a website also https://www.azuracast.com/
it does require alot of ports “possibly due to managing multiple stations” if the user wanted that.
Hi. I have problem for configuration with the .env file. Did you managed to install Azuracast on CasaOS? Have you a recipe?
Tricky installation, I didn’t managed :frowning: Someone to help us? :kissing:
Finaly I managed to produce a docker-compose file for azuracast. I limited to 10 open ports to host 10 webradios.
version: '3.8'
  azuracast:
    image: azuracast/azuracast:latest
    container_name: azuracast
    restart: always
      - AZURACAST_DC_REVISION=1
      - MYSQL_ROOT_PASSWORD=azuracastrootpass
      - MYSQL_DATABASE=azuracast
      - MYSQL_USER=azuracast
      - MYSQL_PASSWORD=azuracastpass
      - AZURACAST_HTTP_PORT=80
      - AZURACAST_HTTPS_PORT=443
      - AZURACAST_VOLUME=/var/azuracast
      - /DATA/AppData/azuracast/stations:/var/azuracast/stations
      - /DATA/AppData/azuracast/config:/var/azuracast/config
      - /DATA/AppData/azuracast/db:/var/lib/mysql
      - /mnt/Storage1/media/Zik:/var/azuracast/uploads
    ports:
      - "80:80"
      - "443:443"
      - "9550:9550"
      - "9551:9551"
      - "9552:9552"
      - "9553:9553"
      - "9554:9554"
      - "9555:9555"
      - "9556:9556"
      - "9557:9557"
      - "9558:9558"
      - "9559:9559"
    networks:
      - azuracast_net
networks:
  azuracast_net:
    driver: bridge
You need to create a .env file with this informations in the same directory directory of docker-compose.yml
AZURACAST_VOLUME=/var/azuracastAZURACAST_DC_REVISION=1
Have a good listening :wink:
Hello, would you be able to make a pull request?
I successfully set up AzuraCast on CasaOS using Docker. Initially, I faced challenges with port configurations and volume mappings. After adjusting the .env file and ensuring the necessary ports were open, everything started working smoothly. It’s a bit intricate, but once configured, AzuraCast runs seamlessly on CasaOS.
