Hi, i never realy got Matrix/Synapse to run propperly and without unnessecary effort via Docker.
With installing the newest ubuntu version there is no installable package as some depencies are missing, so it would be a blessing to have an easy to use and one click installable instance of Synapse with an accessible config folder. Also, i think it would boost the number of instances, as Matrix/Synapse is not known to be very user friendly in terms of Installation and configuration.
Hello, can you post more about it and links to Github and the docker image?
