The ZimaOS using BigBear apps just doesn’t have Scrypted at all.
For most people using ZimaOS, this would stop - it’s not in the list, I wouldn’t know what else to do.
I deleted the app store from ZimaOS, and then put in the BigBear CasaOS store, but it doesn’t appear to work using the CasaOS app store on ZimaOS. In general, what I’d really like is if BigBear can add Scrypted on the ZimaOS app store.
Seems like problem with refresh app list in CasaOS/ZimaOS.
People report (this is also my experience), that new apps (and new versions of old added apps) are not shown in app list, although there are in github. This problem some poeple resolve with reboot OS, but I found, this is not guaranteed. Sure is to stop CasaOS services and start in specific order! This refresh app list.
Scrypted is available in Big Bear CasaOS repo, so this is available also for ZimaOS. There are some differences- ZimaOS is closed source, only x86, specialized HW - zimaboard, management of disks etc. But repos works in same way.
This is an interesting post - you’re saying that the same apps should be in both CasaOS and ZimaOS, but I haven’t seen that at all.
CasaOS hasn’t been updated since 2024. ZimaOS was just updated in April 2026. The ZimaOS still shows BigBearCasaOS as the app store of docker applications, but does not show Scrypted in the list on ZimaOS. It does show Scrypted on CasaOS. That tells me that there’s a problem - I don’t want to delete the BigBearCasaOS that ZimaOS installs as default.
Are there two separate BigBearCasaOS lists, one for CasaOS, one for ZimaOS (I wouldn’t expect, but who knows?) - Are there configurations for a single list that says one is for CasaOS, one for ZimaOS (I also wouldn’t expect this) - so why does Scrypted show on CasaOS, but not show on ZimaOS?
small update: When I install ZimaOS, there’s 160 apps from BigBearTechWorld repository. When I delete and then add BigBearTechWorld repository from https://github.com/bigbeartechworld/big-bear-casaos/archive/refs/heads/master.zip it says that it now has 387 apps (including the ‘store’ repository and the BigBearTechWorld repository, and now has scrypted in the list.)
