[Request] Zotero on CasaOS
I use Zotero installed on my mac, but now with CasaOS, it would be awesome if I could have it on a server! :slight_smile:
Zotero is a free tool that helps to manage and cite research documents and references.
I would like to check if I could have it on server side, with all the documents on Nextcloud. :slight_smile:
This is the docker I found, even not having tested it:
Thank you for the kind support.
Hi @dragonfire1119 , tagging you (not to put any pressure - that’s not at all my intent) but just in case you’ve missed it.
Can you let me know if is this docker link enough? Is there something more I can search to help getting this?
My purpose is to get Zotero; Calibre and Nextcloud “in sync” in same place through CasaOS. This would be a really awesome setup for researchers and book writers.
Once again, thank you so much for what you’re doing, building, supporting and driving this community. :raised_hands:
This has been added:
Thanks for the suggestion! Feel free to suggest more!
Thank you so much! I really appreciate the help! :raised_hands:
