Seafile isn't starting because of env file not set
Trying to get the Seafile to work and the Env isn’t setting correctly I am using default settings
big-bear-seafile     | *** Running /etc/my_init.d/01_create_data_links.sh...
big-bear-seafile     | *** Booting runit daemon...
big-bear-seafile     | *** Runit started as PID 21
big-bear-seafile     | *** Running /scripts/enterpoint.sh...
big-bear-seafile     | 2025-01-02 06:23:00 Nginx ready
big-bear-seafile     | 2025-01-02 06:23:00 This is an idle script (infinite loop) to keep container running.
big-bear-seafile     | [2025-01-02 06:23:02] Skip running setup-seafile-mysql.py because there is existing seafile-data folder.
big-bear-seafile     | waiting for mysql server to be ready: mysql is not ready
big-bear-seafile     | [01/02/2025 06:23:02][upgrade]: The container was recreated, start fix the media symlinks
big-bear-seafile     | mv: not replacing '/shared/seafile/seahub-data/avatars/default-non-register.jpg'
big-bear-seafile     | mv: not replacing '/shared/seafile/seahub-data/avatars/default.png'
big-bear-seafile     | mv: not replacing '/shared/seafile/seahub-data/avatars/groups'
big-bear-seafile     | [01/02/2025 06:23:02][upgrade]: Done
big-bear-seafile     |
big-bear-seafile     | Error: .env file not found.
big-bear-seafile     | Please follow the upgrade manual to set the .env file.
big-bear-seafile     |
big-bear-seafile     | Traceback (most recent call last):
big-bear-seafile     |   File "/scripts/start.py", line 94, in
big-bear-seafile     |     main()
big-bear-seafile     |   File "/scripts/start.py", line 79, in main
big-bear-seafile     |     call('{} start'.format(get_script('seafile.sh')))
big-bear-seafile     |   File "/scripts/utils.py", line 70, in call
big-bear-seafile     |     return subprocess.check_call(*a, **kw)
big-bear-seafile     |            ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
big-bear-seafile     |   File "/usr/lib/python3.12/subprocess.py", line 413, in check_call
big-bear-seafile     |     raise CalledProcessError(retcode, cmd)
big-bear-seafile     | subprocess.CalledProcessError: Command '/opt/seafile/seafile-server-12.0.6/seafile.sh start' returned non-zero exit status 255.
For now, I’ve downgraded to v11 to get this fixed right now.
Thank you much for looking into it!
