Learn how to install Immich on Dockge for a self-hosted photo and video backup solution directly from your mobile phone. Protect your precious memories effortlessly!
About: Self-hosted photo and video backup solution directly from your mobile phone.
Hi dragonfire1119,
Thanks for the great video. I copied your yml into dockge and it works. One more question I have is how I can modify the yml file to set up the immich access to external library. I have a folder “/mnt/NAS10T/Photos” on my NAS that stores all my original photos and videos.
I tried to add:
immich-server: volumes:
# Mounting directories for persistent data storage
- /mnt/NAS10T/Photos:/usr/src/app/external
But it doesn’t seem to scan my library. Any help would be highly appreciated!
Best,
sean
Hello seanchs,
Have you seen this tutorial:
I checked out the tutorial but still can’t make it work. Below is what I have. Appreciate your generous help!
The xompose.yml in dockge:
immich-server:
container_name: immich-server # Name of the running container
- immich_upload:/usr/src/app/upload
- ${EXTERNAL_PATH}:/usr/src/app/external
immich-microservices:
As for the enviroment variables, I am not sure where to put it. I noticed at the bottom of dockge, there is a block “.env” (sorry I can’t attach the screenshot). Below is what I added:
EXTERNAL_PATH=/mnt/NAS10T/Photos
On the Immich Web GUI, I added import path:
You’re welcome!
Here is an example:
version: '3.8'
immich-server:
image: your-docker-image-for-immich-server # replace with the actual image name
DB_HOSTNAME: immich-postgres
DB_USERNAME: dockge
DB_PASSWORD: dockge
DB_DATABASE_NAME: immich
DB_PORT: 5432
REDIS_HOSTNAME: immich-redis
IMMICH_MACHINE_LEARNING_URL: http://immich-machine-learning:3003
EXTERNAL_PATH: /mnt/NAS10T/Photos
container_name: immich-microservices
image: your-docker-image-for-immich-microservices # replace with the actual image name
DB_USERNAME: dockge
DB_PASSWORD: dockge
DB_PORT: 5432
immich_upload:
Copied your example syntax to the compose.yaml. Got an error message when trying to save the yaml:
# Setting environment variables
DB_USERNAME: dockge
DB_PASSWORD: dockge
DB_PORT: 5432
- EXTERNAL_PATH=/mnt/NAS10T/Photos
seems the syntax is not correct. I removed the “-” in the beginning but still won’t work.
It was correct, but it didn’t go with the syntax of the rest. I changed it to Dictionary Format instead of list format.
version: '3.8'
immich-server:
DB_USERNAME: dockge
DB_PASSWORD: dockge
DB_PORT: 5432
DB_USERNAME: dockge
DB_PASSWORD: dockge
DB_PORT: 5432
immich_upload:
Tried your code but unfortunately still No luck. I also set up via Immich web UI for the external library path. This is a bit mysterious to me now…
Could you let me know if there are any errors in the logs?
