Solution for How to increase maximum Docker Network
When You achieve limit of 30 created docker networks, You cannot add new app (which require their own network). casaOS during install app display error: “docker: all predefined address pools have been fully subnetted
You can manually clear some unused:
# list all
docker network ls
# remove net. <NETWORK_ID> or <NAME>)
docker network rm <NETWORK_ID>
# remove all unused
docker network prune -f
I do not understand, why this limit was made so small. But solution is simply:
Create (or edit) on Host: /etc/docker/daemon.json
   "default-address-pools": [
            "base":"172.17.0.0/12",
            "size":16
            "base":"192.168.0.0/16",
            "size":20
            "base":"10.99.0.0/16",
            "size":24
First two are default docker address pools, last is one of the private network.
Restart service docker:
sudo systemctl restart docker
Wait a while. And see webUI, 80 % of apps works, some are gray. You need to click on them for reload.
There is handy one-liner for list all containers and their networks- network size and container itself IP inside container:
sudo docker ps -aq | while read cid; do
  cname=$(docker inspect --format='{{.Name}}' "$cid" | sed 's#^/##')
  docker inspect --format='{{range $net,$cfg := .NetworkSettings.Networks}}{{$net}} {{$cfg.IPAddress}}\n{{end}}' "$cid" |
  while read net ip; do
    subnet=$(docker network inspect "$net" \
      --format='{{if .IPAM}}{{(index .IPAM.Config 0).Subnet}}{{else}}-{{end}}')
    printf "\e[1;34m%-40s\e[0m  %-15s  %-30s  \e[1;32m%s\e[0m\n" \
      "$cname" "$net" "$subnet" "$ip"
  done
done
Tested for docker version 28.5.2, which is apt-hold for upgrade, until fix this issue.
