Ssl on containers through cloudflare: SOLVED
I’m using cloudflared. I have several containers installed. Only one has ssl, the rest doesn’t.
Mealie (which isn’t important) has it, Home Assistant, Immich and Nextcloud doesn’t. They are kinda important.
The tunnels I made are the same, only changed the subdomain and port number
Any ideas?
EDIT: Was just cache in my browser that pointed to http, not https
