Yeah I am going to have to find a better way to set up a home server
this is not going to work on the pi5 for me
now I have to work out how to uninstall casaos
pi5 is annoying
ok uninstall was very easy
thank you for all your help
Appreciate this! Can you explain how to utilize a CIFS mount for the user data dir? I mapped the container /var/www/html/data path to the mount in NextCloud settings in CasaOS to no avail.
I’ll try to explain it:
- Manually mount the CIFS share:
sudo mount -t cifs -o username=your_user,password=your_pass //server_ip/share_name /mnt/nextcloud_data
- Add it to
/etc/fstabfor persistence:
//server_ip/share_name /mnt/nextcloud_data cifs username=your_user,password=your_pass,uid=33,gid=33,iocharset=utf8 0 0
Tip: You can store your credentials in a separate file (e.g.,
/root/.cifs_credentials) for better security. Format:
username=your_user
password=your_pass
Then modify /etc/fstab:
//server_ip/share_name /mnt/nextcloud_data cifs credentials=/root/.cifs_credentials,uid=33,gid=33,iocharset=utf8 0 0
- Update Docker Compose or Docker run to map the CIFS share:
- /mnt/nextcloud_data:/var/www/html/data
- Set permissions so Nextcloud can access it:
sudo chmod -R 755 /mnt/nextcloud_data
- Restart the container and verify in Nextcloud.
Always backup any data that’s important.
Love this video, finally I’m almost up and running with a domain, Cloudflared tunnels and nextcloud. But I can’t seem to get https (although there is with Cloudflare) nextcloud can’t see it so won’t respond when I try services that need the (s) like password manager that required https.
can anyone help me force https or just trust the domain its pointing to?
p.s. I have Cloudflare set to strict in the ssl settings
Thanks
Hi !
I succeed to overpass the “trusted domains” issue.
You can add the “TRUSTED_DOMAINS” key and the “local host” value in the container setting (as in the following picture)
My actual configuration is a Rpi 5 8Gb, with Raspberry OS (Debian 12) and CasaOS 0.4.15.
