First off any help is appreciated. I’m unable to update Nextcloud. I receive this message. " Please use the command line updater because updating via browser is disabled in your config.php.", I already tried to set ‘upgrade.disable-web’ => false, in the config, but the message remains the same. I’ve did some research and was told to run sudo -u www-data php occ upgrade -v. I tried running it via the command line of Casa OS and as well as in the command line of Nextcloud.
