Unifi Network Application not installing properly
Hi Team, I am trying to install the Unifi Network Application on my Raspi 5 on Casa Os.
I start with the readme that says to get the init-mongo.js from big-bear-video-assets.
I can execute the command without error and then install the application without fault, but I cannot launch it. Upon further Investigation I found that in my init-mongo.js it just says: “404: Not Found”, and I tried to search for it directly on github
Where it should be: “https://raw.githubusercontent.com/bigbeartechworld/big-bear-video-assets/main/how-to-install-unifi-network-application-on-portainer/init-mongo.js”
and: GitHub - bigbeartechworld/big-bear-video-assets
Neither in there, nor in the casa-os folder is the proper file or file structre where the download should be.
Is there something wrong with my Installation or can I just not see the proper file?
Please can someone help me?
Hi @pius1701 and welcome here!
I spent some time to search proper URL. And new URL is:
It is folder. Here You can find what You need.
Thank You for feedback, it can be now changed in script via git PR.
edit:
github PR was accepted and merged!
