Unlock Language Freedom: Easy LibreTranslate Setup on CasaOS
Dive into the world of unlimited language accessibility with our step-by-step guide on installing LibreTranslate on CasaOS using BigBearCasaOS. Whether you’re a language enthusiast, developer, or just love exploring new software solutions, this video will walk you through the entire process, ensuring a seamless installation. Say goodbye to language barriers and hello to open communication with LibreTranslate. Don’t let complex installations intimidate you; let us guide you through every click and command. Watch now to revolutionize your language tools setup!
For all:
there is no “+ add language” button in web UI frontend. If You want to add some language, You must:
edit App Settings in casaOS dialog. ENV variable: LT_LOAD_ONLY add code for new language pl, cs, … List of available languages here.
These docker preconfigured default pkgs:
en,fr,es,de,it,pt,ru,ja,zh
are 2,1 GB. If you do not use some of them, just delete it from path:
/DATA/AppData/big-bear-libretranslate/.local/share/argos-translate/packages/
and restart container with env: LT_LOAD_ONLY without these langs. Leave unwanted lang here will download it again!
