siniux
December 3, 2023, 2:18am
Hi there! Big noob here.
I used your helper script to install CasaOS on a proxmox container.
My plan was to migrate my Windows Plex install to this CasaOS container and all was more or less going great until I bumped on this problem…
Although on the “Storage” - “Drive” all my HDDs show, I can’t seem to mount them or access them anywhere.
Am I doing something wrong? Should I be “passing through” those hdd drive from Proxmox?
Help is realllllyyy needed.
Thanks!
siniux:
1. Prepare the Drive on the Proxmox Host
a. Backup Data:
Ensure all important data on the hard drive is backed up, as formatting will erase everything.
b. Identify the Drive:
Use lsblk or fdisk -l to identify the drive on the Proxmox host. Let’s say it’s /dev/sdx.
c. Format to ext4 (Optional, if needed):
If the drive is not already formatted to ext4, or if you want to reformat it, use:
sudo mkfs.ext4 /dev/sdx
Replace /dev/sdx with your actual drive identifier.
2. Pass the Drive Through to the LXC Container
a. Edit Container Configuration:
Edit the container configuration file located at /etc/pve/nodes/<node>/lxc/<container_id>.conf.
Add a line for the drive:
mp0: /dev/sdx,mp=/mnt/drive
/dev/sdx is your drive.
/mnt/drive is the mount point inside the container.
b. Restart the Container:
Restart the container for changes to take effect.
3. Mounting Inside CasaOS Container
a. Access the Container:
Access the container’s command line.
b. Create Mount Point (if not automatically created):
Create a directory to mount the drive:
mkdir /mnt/drive
This step might be redundant if the mount point is automatically created by Proxmox as per the configuration.
c. Check the Drive:
Use lsblk to check if the drive appears inside the container.
d. Mount the Drive:
If the drive is not automatically mounted, you can manually mount it:
mount /dev/sdx /mnt/drive
Ensure /dev/sdx and /mnt/drive or /DATA/AppData match your drive identifier and mount point.
siniux
December 5, 2023, 12:32pm
3
Perfect!
Thank you very much!
