Wire guard easy update?
I just installed this and when I open it and sign into the web UI I get a notification that a major update is available. When I try to change the docker to the “latest” in settings (from ver 13) the docker container stops working and I get a notification saying it’s unwell. How would I or anyone go about updating wire guard to the latest version?
Edit: I’ll also add that this was installed from the bigbear app store
Hello, thanks for bringing this to my attention I have merged the PR.
Thanks Chris. Is this something I could have done myself? I value your time for bringing all this together and would prefer not bothering you for this minor stuff.
Thanks again
wg easy now says container unhealthy after update to 14, wont launch.
installed wgeasy from the vanilla casa repo end copied json and config to get my vpns back. this one is still on version 13.
