Added Nextcloud to BigBearCasaOS
Thanks it works now after adding ‘overwriteprotocol’ => ‘https’,
But now it’s impossible to use it with http :frowning:
overwriteprotocol You setup in Nextcloud?
But the name is very expressive. It do redirect, not option use both.
Sorry for the short description. I have installed NPM and tried to use Nextcloud via SSL, but the App Passwords didn’t like http. After turning on ‘overwriteprotocol’ => ‘https’ in nextcloud config it works now.
hi, can you show me how to move the nextcloud storage to another disk? because my disk wont merge i dont know why
thankyou
Hi @mranything_savior and welcome here!
What is disk merge? And what are You trying to do?
Never mind. Stop container NextCloud. Put data to another path (for example mounted disk …), edit App Settings in CasaOS (using Volumes, remove old path, use new path) and start container.
If You have important data in NextCloud, be always sure, You have latest copy as backup.
salio una nueva version de nextcloud como se instala?? hablo de la version 32.0.2
I keep getting this error:
HTTP headers
Some headers are not set correctly on your instance - The `Strict-Transport-Security` HTTP header is not set (should be at least `15552000` seconds). For enhanced security, it is recommended to enable HSTS.
What is the best way to resolve this issue? Every where I look, it says to find folders or files that I do not see installed. Please help.
Hi @machen and welcome here!
Check this advice, if it is Your scenario:
thanks, this was my problem, mine had the Ip addres and port to acces nextcloud, i changed it my domain address includding https:// and it worked
Thanks @j900, I changed the overwrite.cli.url line and that seemed to remove the error.
