Hello,
I installed nextcloud on casaos with help of the following tutorial: Added Nextcloud to BigBearCasaOS
And Im running into errors in the administration settings of nextcloud.
Im trying to fix the following errors:
Some headers are not set correctly on your instance - The Strict-Transport-Security HTTP header is not set (should be at least 15552000 seconds). For enhanced security, it is recommended to enable HSTS.
Accessing site insecurely via HTTP. You are strongly advised to set up your server to require HTTPS instead. Without it some important web functionality like “copy to clipboard” or “service workers” will not work!
I cant seem to find the needed files to modify so i can fix these errors.
Any help would be apreciated!
