When you’re upgrading your storage or adding additional space to your CasaOS setup, you’ll need to copy existing data to a temporary directory before mounting the new drive. This process involves identifying the new drive, formatting it, and ensuring all your data remains intact and accessible. Here’s a step-by-step guide to doing just that.
Step 1: Identifying the New Drive
Before you can format and mount your new drive, you need to identify it. The lsblk -f command is a simple way to do this:
- Open your terminal.
- Type the command:
lsblk -f - Look for a drive without a filesystem type — likely your new, unformatted drive.
Alternatively, use Drive IDs for Better Accuracy:
- Use the following command to list all drive IDs:
This command will provide a list of all available drive IDs, making it easy to identify the correct drive based on attributes such as model name or size.ls -l /dev/disk/by-id/ - Look for the drive that matches your new hardware by checking its attributes, such as size or model name. The drive ID will be in the format of
/dev/disk/by-id/[unique-id], which you can use for better accuracy when performing operations on the drive.
Step 2: Copying Existing Data to a Temporary Directory
Before formatting the new drive, ensure that you have a backup of your existing data. Use the following commands to copy your data:
- Create a temporary directory to hold your data:
sudo mkdir /tmp/appdata_backup - Copy the data from
/DATA/AppDatato the temporary directory:
Thesudo cp -a /DATA/AppData/. /tmp/appdata_backup/-aoption in thecpcommand preserves the permissions and ownership of the files.
Step 3: Formatting the New Drive
With your data safely backed up, it’s time to format the new drive:
- Format the drive with the ext4 filesystem:
Warning: Double-check the drive identifier to avoid data loss. You can also use drive IDs for better accuracy:sudo mkfs.ext4 /dev/[your-drive-name]sudo mkfs.ext4 /dev/disk/by-id/[your-drive-id]
Step 4: Mounting the New Drive
Now, mount the new drive to the original location of your data:
- Mount the drive:
sudo mount /dev/[your-drive-name] /DATA/AppData - Restore the data from the temporary directory back to
/DATA/AppData:sudo cp -a /tmp/appdata_backup/. /DATA/AppData/
Step 5: Automating the Mount at Boot
To ensure your drive mounts automatically on boot:
- Add an entry to
/etc/fstab:echo "/dev/[your-drive-name] /DATA/AppData ext4 defaults 0 0" | sudo tee -a /etc/fstab - Test the entry to avoid boot issues:
sudo mount -a
Step 6: Cleanup
With your data now safely on the new drive and mounted at the correct location, don’t forget to remove the temporary backup:
- Remove the temporary directory:
sudo rm -rf /tmp/appdata_backup
You’ve successfully upgraded your CasaOS storage capabilities without losing data. It’s always a good idea to back up your data before performing such operations, and remember to verify each step along the way to ensure that everything is proceeding smoothly.
Happy computing with your newly expanded CasaOS setup!
FAQs
Does this change where the OS or any other files are located?
No, the process outlined only changes the storage location for the data associated with Docker containers, specifically the bound or mounted data that containers use to persist information. This includes any volumes or bind mounts that you’ve set up within Docker to store application data outside of the container’s writable layer. It does not affect the location of the operating system files, system configurations, or other non-container files on your system. This ensures that your OS and personal or system-wide files remain intact and in their original locations, providing a seamless transition for your Docker container storage without impacting the rest of your system’s setup.
